 Topic: Nsr250r MC16 problems - help (Pics)
Flyboy
What about the carbs? PICS
Flyboy » Mon Feb 19, 2007 3:52 am
Thanks Matt, SLF-951, I'll do those steps you mentioned and report back in a few days or so. Worse comes to worse, I'll be inquiring with you about makin an order Matt! Laughing
How about these carbs tho, with those settings I mentioned..could it be contributing to the trouble? I believe the carb is stock setup since it has non adjustable needles, 115 MJ's and 35 SJ's. But should the PJ's be blocked off as they are? I read the articles in the "workshop" page, but didn't specifically talk about the MC16
PICS of 'er: http://www.bikepics.com/members/canflyboy/
Appreciate it eh Laughing
Her other symptoms were:
-Would quit on me like she was running out of gas if I had run her for 5 mins at WOT (MJ issue?)
-Will start up on 1-2 kicks when warm, a bitch when she's cold tho
-front cylinder fires right away, rear spits and sputters a lil till warmed up
Keep in mind its about -10 outside and winter won't let up for another 6 weeks at least, so I can't run the dam thing unfortunately to do a plug chop. Just going on her symptoms from the fall.
