I've got an MC16 with 100 in one cylinder and 90 in the other
Her Symptoms:
-Hard to start when cold, 20-40 kicks! (Compression issue?)
-Hesitant between 6-7k rpm, not smooth troughout rpm range, solid after 8500ish (Carb issue?)
-Smokes like a veteran! (Comp issue?)
-On cylinder is slower to fire up than the other (Comp issue!)
So, pretty sure i have all the indicating signs haha. Thought I'd run it by you gents before I give Tyga some added income and start breaking her into pieces,
