 Topic: Getting ready for spring....
Re: The front plug dies after just a short run...
Andy » Mon Apr 16, 2007 11:00 pm
mister_robato wrote:
looking at the plug and spark....it will spart up through the post to the side...
does that mean that it died from to much compression...
with the tyga pipes?
and the post it broken?
or from heat, and I should go with a 10 instead of a 9?
or is it just from fouling and I should go with an 8 to keep it
hotter and cleaner.
-mr
I'm not entirely sure what you mean here (a little proof-reading of your post before clicking submit would help!) but reading between the lines would suggest a buggered spark plug, or maybe a coil breaking down.
Stick with the recommended BR9ECM spark plugs. Fit new ones if you are unsure of their age and/or condition.
TYGA chambers will have no significant bearing on compression ratio.
