How free to rotate are your power valves? They get clogged and that is the most common cause of blown PGM's. You should be able to rotate them freely by hand, even with the pulley and gubbins still attached.
If you can't, then you need to remove them and clean them before you run the bike again. Easy enough to do, just remember the nut on the pulley is felt hand thread...
