No Spark
pipedreams
No Spark
Sat May 10, 2008 6:20 pm » Post: #1 » Download Post
I have a MC21 that has no spark. Bike has been stood a while & is hopefully going to be used on a trackday in a fortnight. Nice new battery, clean carbs, fresh petrol..........Ignition on no spark.
Very hot PGM quick ignition OFFFFFF.
Any ideas before I go mad!!
Sat May 10, 2008 6:42 pm » Post: #2 » Download Post
Is there 12v getting to the coils?
pipedreams
Sat May 10, 2008 6:57 pm » Post: #3 » Download Post
Nothing coming out & I am reluctant to use an PGM if there is some overload going into the box
Sat May 10, 2008 8:28 pm » Post: #4 » Download Post
Didn't ask what was coming out, I asked what was going in!
How free to rotate are your power valves? They get clogged and that is the most common cause of blown PGM's. You should be able to rotate them freely by hand, even with the pulley and gubbins still attached.
If you can't, then you need to remove them and clean them before you run the bike again. Easy enough to do, just remember the nut on the pulley is felt hand thread... Wink
Sun May 11, 2008 1:03 am » Post: #5 » Download Post
Dave Ett wrote:
...just remember the nut on the pulley is felt hand thread... Wink
Maybe even left-hand thread! Shocked
Sun May 11, 2008 2:00 am » Post: #6 » Download Post
Heh heh, yes that too! It's the heat you know: 42 degrees here. Only us and the mad dogs about...
pipedreams
Sun May 11, 2008 6:41 am » Post: #7 » Download Post
The power valves turn freely when the cables are of etc. The cables seem tight so I will take them off & lube them. When you turn the ignition on should the powervalve motor reset like it does on my RGV & TZR?
Sun May 11, 2008 5:04 pm » Post: #8 » Download Post
If you move it from it's start position yes.
