 Topic: Quick turn throttle
MightBeHRC
MightBeHRC » Thu Jun 17, 2010 7:52 am
From the sums I did Ive worked out that a throttle hub thats big enough to make a difference wont fit inside the original housing - so Im thinking it will be a complete change over.
Why do you say you cant run the oil pump if your only running a single pull cable throttle? I know of two bikes that only run one cable and still have their oil pump running...
