 Topic: wanted mc21 barrel
shmokica
shmokica » Sat Apr 02, 2011 6:32 am
Hi,
Cylinders both look OK. The r one has a small dint right at the top where it meets the head, well above the ring mark, otherwise it's in good condition. Not sure if this imperfection is normal, as the plating is consistent and not cracked. The sp one has a couple of very light vertical scorings, you can still see the cross hatching through it so not damaged. Again maybe this is normal where the ring gap is? I am very particular and I would consider both to be good. If you are interested make me an offer. Smile
