 Topic: HRC 030 Card on MC-28
fontyyy » Fri May 06, 2005 10:13 am
The HRC card advances the timing which will increase the risk of detonation under load and I think I read somewhere it removes any restriction in the higher gears (the same effect was wiresplicing a '21 so it always thinks it's in third) which will increase the amount of load the engine is capable of generating thus exasperating any fueling issues.
I wouldn't run it (especially at high revs in high gears) without having it checked unless I was a plug chop expert (which I'm not).
And mine both (standard and HRC 030) work on the bike with the splice although Andy says others have not.
