Hi,
I normally just undo the lefthand nut, slide off the powervalve actuating lever that
the cables are attached to, undo the two bolts holding the adjuster bracket to the
cylinder and tie-wrap the assembly out of the way. Look at the parts manual to check
for washer positions etc.
