Hobbit210 wrote:I'm certainly NOT an expert with NSR's but IF what you are describing is an electrical 'arcing' sound (a bit like the sound when the spark jumps across the contacts on a sparkplug) then you have an electricla breakdown somewhere in the High Tension side of the ignition.
Do you have WD40 in Greece, if so then spray the coil connections on the HT side. Use a good amount of spray (you can clean it off afterwards). If you then cannot hear the sound there is a breakdown in a connection here.
If it still makes the 'arcing' sound the spray inside the plug caps and also on the outside where the HT lead goes into the plug.
Doing this should show if there is any problems on the HT connections.
If that fails then it's over to the NSR experts.
Mike
I dont see something in coil! And i did that with WD40! it doen't do it every time but sometimes
