 Topic: crank assembly
paul g » Wed Aug 12, 2015 12:56 pm
The workshop manual tells you to apply 3 bond 1207b to the mating surfaces of the crank case halves only, nothing to the bearings.
The bearings have oil feed holes which align with holes on the crank case, you risk blocking these if you apply sealer to the bearing surfaces.
