crank assembly
kukkos
crank assembly
Wed Aug 12, 2015 12:24 pm » Post: #1 » Download Post
Hi to all !
I have to assemble my NSR Sp engine, I ask if for assembly the crank on cranckcase the bearing crank
they must be blocked to the crankcase with loctite?
I read that some people use high temperature grease
I want to avoid the bearing can move on the crankcase (Sliding)
Alessandro
P.S sorry for my bad english Sad
Alessandro Cucco
via Brigate Partigiane 43c
54033 Carrara (MS) Italy
Wed Aug 12, 2015 12:56 pm » Post: #2 » Download Post
The workshop manual tells you to apply 3 bond 1207b to the mating surfaces of the crank case halves only, nothing to the bearings.
The bearings have oil feed holes which align with holes on the crank case, you risk blocking these if you apply sealer to the bearing surfaces.
kukkos
cranck assembly
Wed Aug 12, 2015 5:46 pm » Post: #3 » Download Post
I wanted to avoid that this insert rotating into the seat
see picture.
P.S My yamaha TZ250M 80'S had this problem..... Confused
a high-revving there was a "hammering" on bearing seats.
hope not happen to nsr
Alessandro Cucco
