NXA Selector Drum
tdijam
NXA Selector Drum
Sun Feb 14, 2016 11:50 pm » Post: #1 » Download Post
Wanted , Honda RS250 NXA gear selector drum, street shift pattern, ( 1down -5 up ) Wanted for 2016 Classic TT race bike .
John.
MarkR
Sun Mar 13, 2016 9:21 am » Post: #2 » Download Post
You may find one, but it would probably be easier to learn to shift 1 up 5 down...
Didn't take me long to adjust. In fact, I now prefer it to the traditional shift pattern.
If it ain't broke, fix it until it is.
tdijam
Mon Mar 14, 2016 10:29 pm » Post: #3 » Download Post
Thanks for your reply, the NXA is one I've bought for another rider who rides both road and enduro bike as well race bike , so he prefers the road shift pattern.
I've inverted the lever on the gear shift shaft , not ideal as the angle is not correct, but I think it will work ok.
Yuri
Tue Mar 15, 2016 6:05 am » Post: #4 » Download Post
This is how Suzuki is doing it
MarkR
Tue Mar 15, 2016 8:15 am » Post: #5 » Download Post
The NX5 uses an alternate linkage. Well, less linkage really.
From the parts book, it looks like it's just a male & female M6 rose joint, rather than two male (one LH one RH) and a threaded adjuster rod.
NX5 road shift part numbers are:
24711 NX5 004 - Rod end 6mm, A (Male)
43506 NC8 000 - Rod end 6mm (Female)
I would imagine that the position of the gear pedal and selector shaft is the same or similar on both NX5 & NXA, so it should be possible to buy a couple of M6 rose joints. Getting the correct length would be the hard part.
Yuri
Tue Mar 15, 2016 12:35 pm » Post: #6 » Download Post
MarkR wrote:The NX5 uses an alternate linkage. Well, less linkage really.
Buy normal way threads rose joints the use threaded rod to get the corect lengths
MarkR
Mon Mar 21, 2016 7:47 pm » Post: #7 » Download Post
I've just noticed that there are two gear pedals for the NX5, so it may not be possible to just change the linkage.
24700 NX5 800 - Road shift pedal
