struggling to get piston off.
gazandjen
Sun Jul 03, 2005 12:01 pm » Post: #1 » Download Post
I v'e managed to get the head and barrel off but the piston is troubling me. I have removed both pins but cannot remove the piston from the conrod Crying or Very sad
Whats the best way of getting it off Question
Could anyone suggest a good place to get the barrel redone Wink
Thanks
invigiator
Sun Jul 03, 2005 1:36 pm » Post: #2 » Download Post
Holy crap! I had immense trouble getting my pin out but if it's seized onto the rod I hate to think what you've done to it.
Maybe you could put a clamp around the piston squeezing perpendicular to the axis of the pin.
MC28 SE -sold-
MC21 with RS250 engine -for sale-
MC21 race bike -soon for sale-
gazandjen
Sun Jul 03, 2005 2:13 pm » Post: #3 » Download Post
Laughing no I think you've misunderstood or I have not explained myself correctly Confused
I have taken out the gudgeon/wrist pin both sides (green) but cannot get the centre pin (RED) out Do I knock it out or does it come out some other way?
nsr.wayne
Sun Jul 03, 2005 2:17 pm » Post: #4 » Download Post
the bit you have marked green is the circlip and the red mark is the gudgeon pin,just knock it out.
Sun Jul 03, 2005 2:22 pm » Post: #5 » Download Post
Boil the kettle and make a cup of tea!
Once you've done that, immerse a rag in the hot water left in the kettle. Wrap the hot rag around the piston and then try to remove the gudgeon (wrist) pin. The heat from the rag is often enough to expand the piston just enough to free the pin.
Failing that, use a puller. If a pin puller isn't available you can, in extreme circumstances, tap the pin out, but make sure the con-rod is very well supported so as not to put the big end bearing under undue load.
Tapping the pin out is definitely a 2-man job; one to support the con-rod/piston, one to do the tapping... tapping being the operative word!!
faller
Sun Jul 03, 2005 4:58 pm » Post: #6 » Download Post
You need a pin puller like Andy said or you can make your own. Check out Jaime's site under the Technical and go to the Top End Rebuild page. It has a page picture of basically what it looks like. All you need is a long bolt and a piece of pvc and some washers and nuts. I made one and it works great.
gazandjen
Sun Jul 03, 2005 6:10 pm » Post: #7 » Download Post
Thanks for the help, I will sort one out. Wink
cgallant
2001 Honda RS250
Sun Jul 03, 2005 8:40 pm » Post: #8 » Download Post
faller wrote:You need a pin puller like Andy said or you can make your own. Check out Jaime's site under the Technical and go to the Top End Rebuild page. It has a page picture of basically what it looks like. All you need is a long bolt and a piece of pvc and some washers and nuts. I made one and it works great.
And some chewing gum, duct tape, and a zip tie.
Hmm sounds like Macgyver making a weapon or something?
Charles Gallant
gazandjen
Sun Jul 03, 2005 8:57 pm » Post: #9 » Download Post
Laughing be careful you'll be giving away your age. (along with Magnum PI, Airwolf, Night Rider and the "A" Team)
cgallant
2001 Honda RS250
Sun Jul 03, 2005 10:15 pm » Post: #10 » Download Post
I actually had this same problem with my girl friends MC21 that seized at the last race. had to "drive" it out with someone supporting the conrod.
If I had a choice, I would rather have used a puller, but didn't have the right parts to put one together.
I think I should do that as a just in case tool for the future.
thanks,
Charles Gallant
invigiator
Mon Jul 04, 2005 3:42 am » Post: #11 » Download Post
I used some old nuts and bolts lying around to pull it. In retrospect i should've just measured it and gone to a hardware shop and bought the exact bits, it would've been about the same time but much less painful.
MC28 SE -sold-
gazandjen
Mon Jul 04, 2005 8:51 pm » Post: #12 » Download Post
Thanks to all piston now off
ouch Exclamation
can the barrel be redone Question
it is a gouge/scratch and not a crack.
cgallant
2001 Honda RS250
Tue Jul 05, 2005 6:13 am » Post: #13 » Download Post
Hey, that looks so much like the damage that happened to tam's cylinder/piston!
I can tell you what caused her seize, but don't let her know that I know Smile
Thanks,
Charles Gallant
