Keihin PWM and PWK
Jarrodlim
Keihin PWM and PWK
Sun May 15, 2016 1:54 pm » Post: #1 » Download Post
Hi Guys,
Any idea if a PWK or PWM would work on NSR250 other then pj38 and f3carbs?
Neal
Sun May 22, 2016 1:25 am » Post: #2 » Download Post
They should work if you get the inlet manifolds to connect them , I put Pwk powerjet carbs on my bike
Mon May 23, 2016 12:19 pm » Post: #3 » Download Post
They work well with the 300, but don't expect anything much with the 250, other than a probably loss of bottom-end. You may get a little over-rev, if you motor and expansion chambers are tuned to make use of it.
For the cost, you will more than likely be disappointed. They give a great induction bark though, which is fine until you get to a track day with stricter noise control! Wink
One day* I will fit my PJ38s to the MC16F3, but only for the noise! It would almost certainly run better on the F3 carbs.
*In the very dim and distant future, if I ever even start to build it!
