MC18 6 spoke wheels on MC16
StuRat
Thu Oct 06, 2016 8:17 pm » Post: #1 » Download Post
Will these fit? I sorta decided to keep my MC16 and just have some fun with it. Buying some new fairings and ordering 2 spare motors over from Japan, I want new wheels too.
If the needle isn't bouncing off the limiter, it's not time to shift yet.
tomzilla808
Fri Oct 07, 2016 3:43 am » Post: #2 » Download Post
Anything will fit if you try. I'm waiting on a set of mc21 wheels to fit to my mc16. I have an mc18 swingarm to make it easier if needed. I'll post up some pics in a new thread once I get all the parts here.
StuRat
Fri Oct 07, 2016 7:06 pm » Post: #3 » Download Post
tomzilla808 wrote:Anything will fit if you try.
Just....stop.
Rephrased -
Are the MC18 wheels interchangeable to the MC16 / / yes/no and what's needed
Fri Oct 07, 2016 10:06 pm » Post: #4 » Download Post
The simple answer is no, they are not interchangeable.
The 87 triples are a lot narrower than the 88~97, and the MC16 also has a drive for the odometer built into the wheel.
The easiest option is a complete front-end transplant from a later model; triples, forks, wheel, discs, calipers, fender, clip-ons, the whole lot!
If it's a street bike, you will either need an electronic odometer, or transplant a later transmission and LHS flywheel/sprocket cover as the 88-93 cable is driven off the transmission output shaft.
It's all doable, and it's all easy using only OEM NSR250 parts. But it's not just a case of swapping a wheel. There are other niggles to overcome too, but it's a worthwhile conversion in my opinion.
StuRat
Fri Oct 07, 2016 11:25 pm » Post: #5 » Download Post
Andy wrote:The simple answer is no, they are not interchangeable.
Andy, thank you so much for the post. In the interim of that post and now, I have decided to keep my MC16 original, and when I sell my current Miata restoration project, I will be building my own custom NSR. I am very excited.
