What do you guys use for protecting the paint on the bellypan from the heat of the exhaust? I recently used exhaust wrap for cars, but it's not resistant enough to the heat, and the paint started to blister.
Look on the good old flea bay, i'm sure you can get the proper stuff on there. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Not cheap, but they stick like $h17 to a blanket, don't come unstuck when you wash the belly pan and wear well. I've had them last for a season or more. You'll probably need a couple on the Left, depending on your pipes. _________________ If it ain't broke, fix it until it is.
