Firing and tach issue
Jfarvo
Sat May 20, 2017 12:51 am » Post: #1 » Download Post
Went for a ride today and on the way home the tach Stopped working and the top(rear) cylinder was not firing. Replaced coil and rectifier along with plugs. Still no tach or fire in rear cylinder. Coil tests fine. I would check jets but it appears to be electrical considering no spark and no tach.
Any suggestions?
Bike has always run great with no issues till now.
It's an MC-16 ('87) with 9k kilometers.
Please help
timmyboy757
Mon May 22, 2017 8:20 pm » Post: #2 » Download Post
Have you checked pick up coils at flywheel? If its just on one cylinder and ht coils are good I'd check pick up resistance. Also make sure your connections to ht coils are good and there is no burning around wires or connectors. Good luck!
Jfarvo
Tue May 23, 2017 3:45 am » Post: #3 » Download Post
Replaced cdi for rear and its firing better now. Still missing a tiny bit and tach is a little off so I'll replace the other cdi and see what happens
Jfarvo
Wed May 24, 2017 10:59 pm » Post: #4 » Download Post
Found out rear cylinder isn't firing on idle but will fire at 3k RPMs or higher. Under 3k tach drops to zero. This has had me scratching my head for a little while.
Any suggestions?
Thu May 25, 2017 11:22 am » Post: #5 » Download Post
Could be a duff battery, dirty/faulty pickups, duff coil
