Mc21 carb question
paasker
Mc21 carb question
Mon Jan 01, 2018 4:17 pm » Post: #1 » Download Post
Hi all and happy new year Smile
Been pulling the carburators on my two MC21's apart and have a question regarding what's inside, as I don't think it looks the same way as in the parts manual Confused
The carbs are TA22 B type.
Have the float bowl off. Please see the pic below. I know the location of the slow jet and the main jet (both removed in the picture). But the other brass pipe? It could be the Power jet, but in the parts manual they look different i think. The tubes got #55 stamped on them, so some kind of jet i must be.
https://www.motorcykelgalleri.dk/album/storbilledevisning/16843-gamle_knallertdele_jeg_har_liggende?n=409819
The carbs have been sitting on the bikes for some years with gas/oil mixture in the bowls, so the jets have changed color over time. Would they need replacement for new or do you think they're still fine? Just thinking if the gas has "been eating" the material?
Kind regards
Martin
apf
Tue Jan 02, 2018 5:49 pm » Post: #2 » Download Post
Mine are the same - someone correct me if i'm wrong, but I believe they're sometimes referenced as "air jets". They're not removable, but I try to shoot some carb cleaner in there.
Discoloration of the jets shouldn't be an issue as long as you give them a thorough clean.
paasker
Tue Jan 02, 2018 5:59 pm » Post: #3 » Download Post
Ok, thanks Smile But where should that power jet be then? a bit puzzeled Smile
hiding
Tue Jan 02, 2018 6:48 pm » Post: #4 » Download Post
Hi there
The power jet is hiding under the large aluminium screw in the float chamber, choose a good fitting screwdriver tap it on top to shock it and make sure to keep the pressure on because they burr easily,
all the best,
jonmac
paasker
Fri Jan 12, 2018 7:25 pm » Post: #5 » Download Post
Thanks for the answers. Found the aluminium screws the tro that weren't burred came off and the power jets were blanks. So i assume they are the same on both sets of carbs since they got quite large main jets 170-180 range.
Mon Jan 15, 2018 10:12 am » Post: #6 » Download Post
NEVER assume anything with jetting!
paasker
Thu Jan 18, 2018 8:16 pm » Post: #7 » Download Post
you might be right about that. Haven't assembled them yet so will try once more
paasker
Fri Jan 19, 2018 7:11 pm » Post: #8 » Download Post
Those two alu screws are stuck and the heads are busted Sad Any cure other than drilling them out??
Can the screws be purchased anymore? Can't find it in the parts manual, only the Power jet.
