Air filter / element
nigel
Sat Jan 25, 2020 11:47 am » Post: #1 » Download Post
What's the options for aftermarket airfilters / elements for a mc21
Half the strokes, twice the fun
Sat Jan 25, 2020 1:29 pm » Post: #2 » Download Post
I presume you mean a replacement filter for the standard one in the airbox, or are you talking pod type filters ? if you're after pod type, the best are Ram Air, don't go for the other type with the chrome end, not sure if the oem is still available, if not, tyga may be your best bet, or good old bay of e for aftermarket.
nigel
Sat Jan 25, 2020 4:29 pm » Post: #3 » Download Post
Yes filter for standard air box done the eBay thing other than oe one I could only find a dk filter but never heard off them
Sun Jan 26, 2020 3:41 am » Post: #4 » Download Post
If you're set on using the airbox, I'd recommend one of these panels, cut to fit...
Ramair panel filter
Make sure you select the correct size!
nigel
Sun Jan 26, 2020 11:49 am » Post: #5 » Download Post
I found those panels online last night I have one on its way 👍
Sun Jan 26, 2020 10:29 pm » Post: #6 » Download Post
Good stuff, Nigel.
We have a laser at work now that we're using to etch serial numbers on our calipers and master cylinders, that can also be used to cut. Might see about cutting some NSR panel filters later in the year.
