Mc21 USD forks
swerace
Mc21 USD forks
Wed Apr 15, 2020 10:03 am » Post: #1 » Download Post
i am considering mounting usd-fork on my mc21 sp. If I choose rvf400, what triple clamp should I have? Tyga? Or can the rvf triple clamp be modified? can I use the NSR wheel, caliper and brake discs?
Im happy for all help and advice i can get Smile Its a street bike and more for the look Embarassed Wink
Upgrade ?
Wed Apr 15, 2020 11:50 am » Post: #2 » Download Post
Hi there yes you can use the 35 yokes you need to grind the weld off under the the stem of both yokes
21 an NC 35 use 21 stem in 35 lower re weld you need a Tyga steering restrictor because the lower hits the radiator on The rhs , the 35 brakes are good to use also 21 front wheel you need 35 spindle and 2 of the thicker 21 spacers to centralise the wheel
That’s about it 👍 jonmac
swerace
Re: Upgrade ?
Wed Apr 15, 2020 1:01 pm » Post: #3 » Download Post
Johnnymac wrote:Hi there yes you can use the 35 yokes you need to grind the weld off under the the stem of both yokes
Thank you so much! That was very helpful! Very Happy
