The oil pump is mechanical, so no the card won't effect its' operation. The cold start solenoid however, that opens the pump up a little extra when the motor is first started, isn't accomodated for on the HRC harness so I wouldn't imagine the card is programmed to activate it.
Same goes for the carbs. Only the air solenoids are controlled electronically. You may find the 030 card opens and closes them differently. _________________ Andy.
Andy wrote:The cold start solenoid however, that opens the pump up a little extra when the motor is first started, isn't accomodated for on the HRC harness so I wouldn't imagine the card is programmed to activate it.
Nice, thanks Honda. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Well, the 030 card was never meant to be used on a road bike with the oil pump - only on a race bike with pre-mix! _________________ Andy.
