Rear fairing removal
anonymous.shyster
Sat Aug 08, 2020 4:54 am » Post: #1 » Download Post
Got an MC21 with stock fairings. Need the rear tail piece off. How is it removed as one piece, preferably?
So far have the four large screws out, but something is holding it at the rear. Perhaps tail light related, don't know.
Max
Sat Aug 08, 2020 6:20 am » Post: #2 » Download Post
It is a bit of a fiddle but it will come off as one piece.
Once the four big retaining screws and the door to the glove box are removed you have to slide it backwards a little and gently prize the panels apart at the bottom to clear the rear brake master cylinder.
That should be it, once you clear that obstacle all you have to do is remember to disconnect the stop/tail light and off it comes.
Removal
Sat Aug 08, 2020 8:25 am » Post: #3 » Download Post
Hi there there are two m6 bolts that hold the black box to the subframe if the rear seat pad is on you need to remove them, I always remove it as one 👍 jonmac
