Mc21 rear spindle spacers
Camo
Mon Aug 24, 2020 11:49 pm » Post: #1 » Download Post
Can anyone clarify which spacers are fitted to a mc21 r model rear wheel spindle
Coming to put mine back together and I think I am missing an outer spacer on the disc side - should there be one sat in the dust seal like on the sprocket side? Bit lost with the parts diagram not sure if it is 42312 kv3 700 or 770 I need? And does anybody have a spare or know where I can get one? thanks all
Tue Aug 25, 2020 4:00 am » Post: #2 » Download Post
Yes, there should be a captive spacer on each side. It doesn't matter if you use 42312-KV3-700 or 770. If you have the one on the sprocket side, you can just get it copied by a local engineering firm.
Max
Tue Aug 25, 2020 6:35 am » Post: #3 » Download Post
David Silver spares is offering the -770 variant as a special order part for about £15 👍
Camo
Tue Aug 25, 2020 8:34 am » Post: #4 » Download Post
Thanks for the answers both. Yes i have the other side so can use that to copy if needs be ta
