Hi all,
Having completed a bottom and top end rebuild, I found my bike was smoking considerably more upon start up than it did before the rebuild. Much less smoke once warmed up.
I’ve adjusted the oil pump ( thanks Andy) so that at WOT, the line on the middle of the pulley meets the marker on the pump body. No marks on my carburettor slides for 50% throttle.
Upon removing my carburettor twice, I found about a small teaspoon of oil in the bottom of both reed cages.
Is this amount of oil normal?
My air filter is OEM and seems somewhat oily?
Any info appreciated.
