MC21 cylinders
Ivor2Stroke
MC21 cylinders
Thu Sep 16, 2021 3:23 pm » Post: #1 » Download Post
hi i am still learning about these nice bikes whats the difference with the L1 and L2 cylinders,and can you mismatch or do you have to use the same numbered cylinders,thanks
tleighbell
MC21 cylinders
Thu Sep 16, 2021 8:43 pm » Post: #2 » Download Post
different cylinders require different pistons. there was a previous post showing compatability. should come up on a search.
Ivor2Stroke
Thu Sep 16, 2021 9:19 pm » Post: #3 » Download Post
i seen L1 & L2 type A and L4 type A too
Fri Sep 17, 2021 3:40 am » Post: #4 » Download Post
There are two things to watch out for...
  1. As already mentioned, the correct piston should be used, however given that these bikes are circa 30 years old, there are often occasions where you may come across re-plated barrels, so the sizing can be incorrect.
    Providing everything is original as Honda intended, the recipe is as follows:
    "A" barrel - "B" piston
    "B" barrel - "no mark" piston
    "C" barrel - "D" piston
    Don't ask me why! 🤣🤣🤣
  2. Do not mix "H" and "L" heads and barrels.
    "H" parts are R model
    "L" parts are SE/SP model
    You can, if you are desperate, fit an "H" head to an "L" barrel, but it will have very low compression, and a significant loss of power.*
    There is no rule against using an "R" head & barrel on one side, and an "SP" head & barrel on the other, but really, just keep it simple. Use either "R" or "SP".
DO NOT be tempted to fit "L" heads to "H" barrels, thinking high compression will give you loads of power... it won't! It will however put a big hole in your wallet when the heads melt and pistons fuse to the barrels! Even in completely stock configuration, the compression is borderline, and I've seen dozens of (maybe more) front heads with signs of detonation. The setup really is well optimised from the factory on all models.
The NSR is extremely sensitive to compression changes, and for virtually every scenario the standard setup is perfect.
Ivor2Stroke
Fri Sep 17, 2021 2:48 pm » Post: #5 » Download Post
so i can use different L cylinders like these L1,L2,L4 cylinders together
Sat Sep 18, 2021 1:28 am » Post: #6 » Download Post
Ivor2Stroke wrote:so i can use different L cylinders like these L1,L2,L4 cylinders together
Yes. Lx heads and barrels together, or Hx heads and barrels together. Just don't mix L & H.
Ivor2Stroke
Sat Sep 18, 2021 7:27 pm » Post: #7 » Download Post
ok cool,thanks for the useful info , much appreciated
