Racer38 could probably help you out with some dimensions, if he's feeling charitable. He has an MC28SP and an NXA in his shed, and knows which way round to hold vernier calipers. I'll ask him. _________________ Andy.
I have an nx5, but Honda have stopped making the clutch frictions. I was hoping to find another model which used the same frictions, thought that maybe the nsr might be the same.
I've tried Barnett, and they're fine for practice. But they fall apart after one race start.
Any suggestions/advice welcome.
These T2 Racing plates are for NF5. No idea if they are compatible for an NXA
https://japan.webike.net/products/24104118.html _________________ Why do things simply when you can complicate them
Nf5 frictions are different to NX5, i have had my NF5 ones relined by a company called Saftec in West Yorks, tel; 01274 862666, quick turnaround, and they have been no problem. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
T2R say they should be able to supply a new set of fibres, but Matsumoto-san says he had a very good used OEM Honda set personally, if it's of any use? Are you racing or parading?
He'll check with his supplier for a price & availability. _________________ Andy.
Pretty sure he means the 20 used plates are friction plates too, but I'll check.
Edit: He says the used ones are friction plates, and good to use for practice and testing to save wear on the new plates for the race(s). _________________ Andy.
