Probably the most tasteful MC16 I have ever seen!
StuRat
Fri Sep 08, 2023 9:08 am » Post: #1 » Download Post
Translated from Japanese. The bike is currently up for sale for 1.5 million yen which is roughly $10,660 USD.
MC16
Modified Points
Engine MC21 (Late) Dry
Electric PGM2 89 HRC Limiter Release
Meter MC18 89
Cab TA21 89
Chamber HRC
Front Fork MC18 89 SP Damping
Stem MC18 88
Swing Arm MC18 88
Rear Shock MC18 1989
wheel with SP tank Front MC18 88~ STD
wheel Rear MC21 STD 17 inch
step Coworth
tire α14 F110.70.17
Tire α14 R170.60.17
Engine Specifications of
Cylinder port Unprocessed
crankcase Unprocessed (Deburring is done)
The engine mount is aligned with MC16, and
aluminum collar is driven into the rubber hole.
Lead valve spacer DMR 1mm
lead valve body MC21 New
HRC recti MC21
insulator MC21 new
primary gear is MC28
Mission 1st to 4th gear MC28
5th and 6th gears incorporate MC18 88 gear.
The maximum speed calculation value is about 198km.
If the needle isn't bouncing off the limiter, it's not time to shift yet.
StuRat
Fri Sep 08, 2023 9:10 am » Post: #2 » Download Post
Fri Sep 08, 2023 11:16 pm » Post: #3 » Download Post
That is indeed, and well modified MC16. The only things I would question are how well the HRC pipes work with the MC21 motor, and how they've set the RC Valves up. But yeah, I like that!
