I have an issue in that my MC18 arrived with non-standard exhausts. Andy thinks they are ETHOS Design.
However I want to improve the way they are mounted to the subframe- the previous owner had one side with a jubilee clip
...and the other with a single self tapper into the plastic of the mudguard. absolute rubbish.
Bike also came without the pillion hangers and pegs so I figured I would get the pillion hangers and I could use those to hang the exhausts but I just matched a set of hangers I got from Oz and as you can see they are wider than the mounting holes...and if you're wondering about the RD500..yes it's wonderful but a crankseal's gone so...there's that to do...the beauty is only skin deep old mates.
In fact hanging brackets I also got from Tyga as a second choice that are supposed to fit an MC18 are also too wide
Me thinks my subframe is built for those foldaway pillion pegs and a hanger which has the sole purpose of hanging the pipes like this pic I grabbed from the net...but the swingarm is diffrent than mine.
OR did the hangers I bought fit something else? U never know with fleabay.
That’s also why your electrics (in your pic) are strapped to the sub frame rather than bolted in place
Due to the mounting brackets being in all the wrong places for your loom
Your fairing is definitely a 1988 R4 and likewise all the fairing brackets
FYI the VIN on the bike is MC181004427 I'm assuming it IS for sure an R2J?
So I think have two choices to try and make the integrity of the bike solid/so everything fits...
-source those upswept pipes, foldaway pegs and exhaust hangers
OR
-find a correct R2J subframe, blast it, powder coat it, and work out some clever way of anchoring the existing pipes.
STOP PRESS: Jauce to the rescue...probably won't be cheap but could anyone verify this as an R2J subframe? (PS after re-re-reading Wayne Gardners 25yrs of neglect thread and studying the pics i realize the answers to everything are all there in black and silver!)
Also forgot to add - check you black under tray / mud guard
Due to 2 verses 1 hanger they are different as the folding pegs need a larger cut out in order to fold away
Which I guess you cut one out or going the other way your going to be left with a gapping hole
It was kinda never ending when I swapped one part out and cause a domino effect of other parts that no longer fitted or worked
Excellent point. How far did my previous owner go in the switch? Wonder which mudguard I have?
Note somebody chopped off the number plate holder..
Apologies for posting these questions and then answering them myself. Just showing my work sir.
I think it's an R2J...check out the parts diagram. It's confusing but it seems to me that everything in a 3 box is R2J and everything in a 4 box is R5K Mine has those 2 vertical stubs.
AND...Jauce is by no means the ultimate authority on the idiosyncracies between parts but their advertised MC18 is same as mine https://www.jauce.com/auction/o1169972024
