Bike won't idle w/o choke
j4m35
Mon Dec 29, 2025 9:58 pm » Post: #1 » Download Post
After sitting for a few months my bike won't idle without the choke. I suspect gummed up or clogged pilot jets but would like advice as to what it could be and how to fix it. Thank you.
ericandchi
Mon Dec 29, 2025 11:14 pm » Post: #2 » Download Post
Assuming the bike ran good in the past then started acting funny after sitting, first thing I would do is pull the carbs and entirely clean them.
Once you got the carbs clean, especially if you found some crud in there , I'd drain any old fuel from the tank. Next I would probably pull the fuel tap and make sure tank is clean. Hopefully the fuel tap screen is doing its thing, but I never trust those so you might add an inline paper filter. Last thing you want to do is fill your clean carbs up with crud!
Let us know how it goes.
