Hi there, I have just got my new nsr250 Mc18 RK5 up and running after buying it a few weeks ago. Took it to the get the MOT, it passed!! I was very happy, so went up the road for about a mile, the indcators started to fade. Then i stopped at a roundabout it cut out, I turned the headlight off it started, went and got some petrol as I thought that maybe the problem, went well for about 5min then started to miss, then power just went and the bike stopped. No very happy as I had to push it for about 2 miles!!! I checked it today and it started for about 2 seconds and went dead.
Any ideas, by the way the battery was new, also the spark plugs.
Is there two stroke oil in it? _________________ MC21SP Plaything
Voltage regulator problem? Battery died and the bike wont run? Hopefully it is just something that simple. _________________ Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
Wrench hit it right, my bike did the same thing with new battery it would go for a while and things would fade, then the tac would go coo-coo and start misfiring and die. I would wait several minutes and it would run a little longer. So installed new after market reg/rec and it would be fine for days, then it would happen again and repeat. Turned outI had a bad harness, replaced that and never came back. _________________
Cheers guys, I'll try and get hold of a Voltage regulator, that is the thingy on the side with the fins?? Any body know a good place to get them? Also can you use other honda types?
I have just charged the battery up it starts, how can I check the coil and the rec/reg are doing their jobs? If the rec/reg had gone would that stop it changing??? I felt the rec/reg it was warm?
They do get hot, hece the need for a big heat sink and fins.
To check the charging circuit, check the voltage on the battery with the engine running above 2000rpm. It should be about 13.5-14.5 volts. _________________ MC21SP Plaything
I Checked the votage on the battery, it was reading about 11.5 to 12, when I reved it to 2,000 it went down to 10, Seams to not getting any charge. Anyway went out for a quick ride, it seamed ok for about five mins, all dash lights bright. Then it got dark so I had to put my lights on, it started to play up, got home this time, in steath mode no lights!!! So it sounds like a Reg? I'll also have a look at the fault finding chart. Anybody know where to get a reg in the UK, and can I use one from a other Honda bike?
Just about any will do, but the genuine Honda ones don't seem very robust. You might be better with an aftermarket one. _________________ MC21SP Plaything
