losing power at high revs
kempo
Fri Aug 26, 2005 2:32 am » Post: #1 » Download Post
I have a 1991 MC 21, fairly stock but de-restricted. I have had it for about 4 months. Bike runs fine around town but once on the motorway and being at above 7000 RPM in 6th for over a couple of Km's the bike starts to lose power, like it is running out of gas, after i pull over the bike often stalls. Once it has been kicked over a couple of times it usualy starts and then runs fine at slower speeds, by this stage i am off the motor way so it does not get a chance to do it again.
To get rid of the obvious, yes there is gas and oil in it and the plugs are new.
Any help on this woud be greatly appreciated as it is doing my head in.
fstnsr
Fri Aug 26, 2005 2:40 am » Post: #2 » Download Post
i had a similar problem. when i had put the fuel line on after taking the tank off i had twisted it and it was starving the bike of fuel like u said so check the fuel line is fine and not twisted or kinked
94 mc28 SE
Fri Aug 26, 2005 8:25 am » Post: #3 » Download Post
Check the tank vent/breather. Sounds like it's blocked and creating a vacuum in the tank, consequently starving the carbs.
Next time it happens, carefully open the fuel filler cap and you will probably hear a slight "hiss" as it's opened.
cgallant
2001 Honda RS250
Fri Aug 26, 2005 3:45 pm » Post: #4 » Download Post
Also check your float height settings. They can sometimes make it seem like the bike is starving for fuel if they are set to high, and not allowing enough fuel into the bowls.
thanks,
Charles Gallant
