Redline or Motul 600
Vin
Sat Sep 17, 2005 6:06 pm » Post: #1 » Download Post
When I bought my MC28 it was using Redline Racing oil. Someone told me that it gums up the carbs. So I switched to Motul 600. Before with the Redline the bike starts with one kick, even when its cold. Now with the motul it takes 4-5 kicks when cold, and sometimes 2-3 when warm.
What do you guys think about this?
Steve C
Sat Sep 17, 2005 7:38 pm » Post: #2 » Download Post
I would try changing you plugs and see if it gets better.
Sat Sep 17, 2005 7:45 pm » Post: #3 » Download Post
I've only ever used Rock Oil except for 1/2 a bottle of Castrol R2 and I have heard questionable things about Motul regarding how thin it is, maybe there's that much of it in the mixture it's causing problems? My '28 ran on premix and the oil pump for the first tankfull when it was rebuilt and it was an absolute bitch to start.
I don't know much about Redline Racing but any manufacturer who claims to have seen a 5% improvement in power (I kid you not, 5%! Read the middle grey box here) by changing oil brands is probably best avoided at any cost.
Part of the problem with 2 stroke oil is even the cheapest nastiest £4 a litre duck oil passes the most stringent of industry standard tests. That and the fact we're always told not to mix brands and people tend to stick to what they know works.
fstnsr
Sat Sep 17, 2005 8:30 pm » Post: #4 » Download Post
i have run some pretty nasty oil ( one would think twice about putting it in a lawn mower) at 50:1 in my cr250 and it never had a problem. starts using castrol tts then elf which i felt was better. now i am using a shell product in my nsr coz it is cheaper and it hasent caused any hart ache yet but am running castrol rs in my kx125
94 mc28 SE
jeff350lc
Sun Sep 18, 2005 9:35 am » Post: #5 » Download Post
i am using motal 600 in both my NSR,s and both start no problem, and run just fine on it.
i also run it in my 350 yam. i had a lot of top end trouble untill i switched to motal 600, from a cheaper oil i was using.
i,ve used rock oil in a GAS GAS 330 trials outfit that got used real hard most weekends for two years, and only needed a ring when we stripped the motor.
Vin
Sun Sep 18, 2005 2:50 pm » Post: #6 » Download Post
I guess I will change the spark plugs and see if it gets better. Do you guys run a HRC030? What temperature should I warm it up to before I start riding?
Sun Sep 18, 2005 10:20 pm » Post: #7 » Download Post
Vin wrote:Do you guys run a HRC030? What temperature should I warm it up to before I start riding?
I run an 030 card and have been known to ride off VERY gently with just 35* on the clock, noramly round at Monkeys at night as I feel bad sat there warming it up at midnight, 45* though normally.
Don't know what I should do really, anyone?
Jezza
Mon Sep 19, 2005 1:44 am » Post: #8 » Download Post
I was breaking a sweat trying to start my bike until I changed my plugs a couple of weekends ago - after that it starts on first kick Very Happy
Myself and all of the NSR riders I ride with in Melbourne have been using Motul 600 and have not had any issues with it - we are using the oil pump and not premix.
Jerry Lai
NSR250 [MC21SP]
Vin
Mon Sep 19, 2005 2:26 am » Post: #9 » Download Post
Cool..I have been warming it up to about 45* too. I think I will order the spark plugs soon..Any suggestions on which spark plugs?
Jezza
Mon Sep 19, 2005 2:46 am » Post: #10 » Download Post
The NGK plugs are the go. Part # BR9ECM
Jerry Lai
NSR250 [MC21SP]
Vin
Tue Sep 20, 2005 1:35 am » Post: #11 » Download Post
Thanks, I will order the plugs
nsrmonkey
Tue Sep 20, 2005 5:55 am » Post: #12 » Download Post
although some people slagged off the Motul 600 i always used to use it in my R, ran the bike on it for 3 years and did a few trackdays and never had a problem at all.
I use Rockoil now but only because i was able to buy a larger amount a bit cheaper than retail, otherwise i would still use the Motul.
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
