I've just put new throttle cables on my 92 MC21R.
My problem is that the throttle won't snap shut when released. in fact it won't move at all unless twisted shut by hand... cruise control...
With no cables connected, the throttle shutting spring seems really powerful so i must be doing something wrong with the cables themselves, but can't see it?
Does everyone else's throttle snap shut on its own when you let go?
If you have overcome this problem yourself could you help me please??
Thanx in advance _________________ After years of moaning about immigrants now i am one...
Make sure you have free play first, if there isnt any this will hold the throttle open. After that check the routing, if the cables cross over this can also cause stiff throttle action. _________________ If I have to take the carbs off once more...
Forgive me if I'm being a doofus - getting on a bit you see - but there isn't a spring in the throttle is there? Just the one on the carbs?
Therefor, I can't see how the throttle will snap shut with no cables attached?
Or is it time to wheel me away for my horlics... _________________ MC21SP Plaything
Make sure that the hand grip is not binding on the outside end of the handlebar (grip touching the handlebar) as this can cause the throttle tube to hang up. Also check that the grip is not pushed to far up on the throttle tube and binding against the throttle/killswitch housing (there should be a plastic washer between the grip and housing). I have seen both of these scenarios cause binding before.
StephenRC45 wrote:Youre doofus Dave, there is a huge spring!
Well having just looked at my NSR, I'll wager £100 there's no spring. The spring is part of the carb assembly, and if you detatch the throttle cables - as in "With no cables connected, the" from the first post.
Or - and maybe I've finally got it - does he mean the slides won't snap shut? To me, the throttle is the bit on the handlebar, the things held shut by the spring are the slides. _________________ MC21SP Plaything
you really need to get out more.......or did you forget to turn your 'pedant' mode off _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
No Monkey, I'm an aircraft engineer, and if the aircrew tell me the navigation system doesn't, I need to know exactly which bit doesn't!
Sorry, but years of being precise has... changed me. _________________ MC21SP Plaything
Quote Dave...Sorry, but years of being precise has... changed me
Is that why you use the wrong plugs in your bike, dont bother to adjust the power valves and wonder why your bike makes 44bhp? lol
When he says this throttle wont snap shut he means the twist grip wont return.. as we have all decided now _________________ If I have to take the carbs off once more...
Must you cling to that? And what did 1 jet change do? Lift power to 51 - proving my statement I'd set it rich having only been thrown together a few days pevious. Sheesh!
StephenRC45 wrote:When he says this throttle wont snap shut he means the twist grip wont return
I don't think he did.
What did he mean when he said 'it's ok with the cables off' then? How did the twistgrip shut? Eh? Eh? _________________ MC21SP Plaything
Dave Ett wrote:what did 1 jet change do? Lift power to 51 - proving my statement I'd set it rich having only been thrown together a few days pevious. Sheesh!
No no no no, mine was "set rich" and gave 57bhp, moved up to 61 with a little advice (and some scraped knuckles) by Steve and Andy, 28 carbs may flow a tad better but they're not fun to work on.
the phrase "lift power" and "51bhp" should never be used anywhere near an NSR250 _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Unless you're de-restricting it perhaps? _________________ MC21SP Plaything
