PGM II 3D?
motulman
PGM II 3D?
Mon Jan 02, 2006 3:53 am » Post: #1 » Download Post
apparently the R5k had a 3D pgm, i am wondering if any of you have used a 3D in place of a pgmII? without any mods, do you guys know if the 3D pgm says "3D PGM" on the box? or will it say PGM II 3D? i am assuming it must say 3D somewhere on the unit,. if the pgm II's are for the mc18 R2/R4 what did the PGM CDI come from if the MC 16 didnt have one i am assuming the PGM CDI is PGM I...do ya follow this?....i tried, any info would help Very Happy
Mark
DAYTONA SPECIAL,74 RD350 LONG ROD, 2 RD200 ELECTRIC'S,88 NSR 250RG, MICRO SPRINT CAR W/CR 250 ENG
Mon Jan 02, 2006 4:38 am » Post: #2 » Download Post
A PGMII unit is off a 89 RK not a 88 R2/R4 and just says PGMII on on it. The R2/R4 used a type of PGMI.
motulman
89 RK?
Mon Jan 02, 2006 5:05 am » Post: #3 » Download Post
like a R5K? could you be more specific and thanks what has a PGM 3D? do ya refer to a R2J/R4K as a mk I and a R5K as a mk II? what about the R6K?
Mon Jan 02, 2006 5:10 am » Post: #4 » Download Post
The R2J and R4J are Mk1 MC18's from 1988, the R5K and R6K are Mk2 MC18's from 1989. The MK2 MC18 RK's were fitted with a PGM II, this had a 3D ignition map (but only says PGMII on the box), where as the RJ's from 1988 were fitted with a type of PGMI.
The MC21 is fitted with a PGMIII but still doesnt say 3D on it.
motulman
RJ's and PGMII and thanks
Mon Jan 02, 2006 5:39 am » Post: #5 » Download Post
hey stephen do you mean RG's from 88 and so then all PGMII's have a 3D map...its becoming clearer! Very Happy
Mon Jan 02, 2006 6:37 am » Post: #6 » Download Post
An RG is an MC16 from 1987 and came before both the RJ and the RK range of MC18's and wasnt fitted with a PGM at all. It had two seperate control boxes the same as the RC30 did. Have a look on the main site under "model history".
motulman
i did and thanks
Mon Jan 02, 2006 6:54 am » Post: #7 » Download Post
i checked all that out very closely i was double checking with someone else,( YOU )it talks about the these items but not in the order or answeres the questions like i wanted to hear them for instance it doesnt say a 3D is a pgm II specifically and it doesnt say that the mk1 uses a pgm I it just says it uses a pgm cdi well i need to know if there is a specific pgm I. i think it is safe to assume that the box marked pgm cdi is #I so thanks for confirming it all for me. now i can buy parts, i down loaded 30 pages of cross referencing info from there between 4 models just to find out what will work with each other and i hope all THAT info is correct and complete, sure would like to see the MC18 parts discription though.
Mon Jan 02, 2006 6:57 am » Post: #8 » Download Post
No worries, glad you figured it all out.
