for the blinkers? i have yet to find it also, perhaps it is missing anybody know where it goes on mchybrid16/18/21 _________________ DAYTONA SPECIAL,74 RD350 LONG ROD, 2 RD200 ELECTRIC'S,88 NSR 250RG, MICRO SPRINT CAR W/CR 250 ENG
Not that easy Luke, they head off into a larger loom. Mine's in the workshop, I'll go have a look... _________________ MC21SP Plaything
there aint one here! where abouts is it supposed to be? what part of the harness the front or the back? i do have another unexplained plug in the back by the indicator and tail lite hook up? i also have a couple on the lead that comes from the main to the fuse box and continues on to the neg batt wire and the tps plus what must be one for the oil pump sys also...thanks _________________ DAYTONA SPECIAL,74 RD350 LONG ROD, 2 RD200 ELECTRIC'S,88 NSR 250RG, MICRO SPRINT CAR W/CR 250 ENG
Hmmm, I checked on mine, and can't find anything that looks like an indicator relay. The front loom runs to the indicators, headlight, and clocks. I'll have a peruse of the wiring diagram and see what I can work out... _________________ MC21SP Plaything
As I suspected, it's done by the PGM unit. If you've a fault, I'd suspect wiring rather than the PGM - I've never heard of the PGM failing for this fault. _________________ MC21SP Plaything
