Whilst im sorting my bike out ive fitted new sprokets and chain, I used a grinder to remove the old one and have now fitted the new chain! ive pressed on the link BUT i dont have a tool to rivet the links up! anybody have a idea how to do this? Iv seen the tools on ebay for £50 but its kinda lot of money for riveting a chain up? if needs must ill buy the tool but if any of you know if theres a seperate tool for this job could you be kind enough and point me in the right direction. Cheers
basically you have to flatten the rivet. You can do this with a chisel if you are handy
Make sure something is on the other side of the chain so you don't put lateral stress on it when doing so.
Or go to a bike shop and see if you can borrow the tool....they do that around here if they know you. _________________
j911brick wrote:I got second dibs on those books you already sold.
I use two hammers. A gurt biggun behind the chain, and a smaller more accurate one to swing at it. Been doing it that way for years. If you do the rivitting near a sprocket, the chain will flex less, though be carefull not to whack the teeth off your sprocket! _________________ MC21SP Plaything
I prefer a big hammer and a REALLY BIG hammer! Best have a big screwdriver to hand too, then you can fix anything! _________________ Andy.
rc46 wrote:Whilst im sorting my bike out ive fitted new sprokets and chain, I used a grinder to remove the old one and have now fitted the new chain! ive pressed on the link BUT i dont have a tool to rivet the links up! anybody have a idea how to do this? Iv seen the tools on ebay for £50 but its kinda lot of money for riveting a chain up? if needs must ill buy the tool but if any of you know if theres a seperate tool for this job could you be kind enough and point me in the right direction. Cheers
If you need the tool I have 2 and you are welcome to borrow one.
Do it properly when it comes to chains... _________________ These aren't the droids you're looking for.
BINKA, thanks for the offer, on the way home i poped into a mates house and he had one, BAST5^*&*& must have been hiding it, Thank you so much for the offer but i have one, all i need now is to forget to return it LOL
Dave Ett wrote:I use two hammers. A gurt biggun behind the chain, and a smaller more accurate one to swing at it. Been doing it that way for years. If you do the rivitting near a sprocket, the chain will flex less, though be carefull not to whack the teeth off your sprocket!
That`s what I like to see, whack it with a big hammer!
I wouldn`t do it though, I bought the right tool cos I`m a big jessie!
A bike shop I knew used to do it this way all the time. They had a small bench vice they used to press the ends over with also. (Obviuosly it wasn`t bolted to a bench at the time)!
