I want to replace the water pump seal on the left hand side.
But before i go through the long process to find parts, I just wanted to ask if there are any other parts i might need to get.
plus i cant open the parts manual so i cant find the part number has anyone got access to it, and does anyone know if the parts are the same as any other honda models. (as NSR parts are very hard to come by!)
To see the manual you may need to increase you screen resolution. If you dont see the menu you will need to download java from java.com _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
Your gearbox oil has emulsified... It means that unfortunately, you have moisture/water getting in there from somewhere, which needs to be rectified. _________________ NSR300R - Why did i ever have a 250...
