Ive done a Quick search and looked in the specs but i cant see the fork Tube diameter anywhere, Im looking at a set of CLIPONS but cant find it!! i thought it was 41mm but i need to be sure before i go and order a set... Cheers
The woodcraft ones are pretty nice (think that's their name) if you haven't decided yet. They're a split design too. _________________ NSR300R - Why did i ever have a 250...
Your all gona have a Laugh.. the only reason i want some is the FECKING ISR brake master cylnder ive got, when fitted in the right place smacks against the clocks on a left turn, If i swap it round with the kill switch it moves it enough down the bar for it not to hit but then the lever dosent feel right so i want them to get slightly (10 - 15 mm is all i need) longer bars!!! fecking upgrades, one thing after the fecking other LOL
did you get me PM, if there gone or wont work, ive found a set on ebay from the US with adjustable poles, £90 inc shipping to the UK!!!! Where did you see these woodcraft ones? How much and do you have a LINK?
Cheers dude, found them, More expensive than the harris ones!!!! think i might get the ones from ebay, they look good and the chap has confirmed there 11.5 inches which is about an inch bigger than the standard NSR ones!!! thall give me enough room from the brake setup without bashing the fecking clocks!!! Rusing fusing thing
