MC21 carb problems
nsr Moggy
MC21 carb problems
Sat Mar 04, 2006 8:03 pm » Post: #1 » Download Post
Hi I have an MC21 and am struggling with a major flat spot at 4000-5500rpm all jets are standard air screw setting standard. Please help I'm begging to lose it
Sat Mar 04, 2006 8:14 pm » Post: #2 » Download Post
Mine turned out to be crank seals.
nsr Moggy
Sat Mar 04, 2006 8:39 pm » Post: #3 » Download Post
can't be the crank seals as there only 150 miles old
fenton
1990 Honda NSR250 MC21
Sat Mar 04, 2006 8:44 pm » Post: #4 » Download Post
are they in right ?
nsr Moggy
Sat Mar 04, 2006 8:46 pm » Post: #5 » Download Post
yes properly sat in groves
fenton
Sat Mar 04, 2006 8:48 pm » Post: #6 » Download Post
are the crank cases sealed ok ?
nsr Moggy
Sat Mar 04, 2006 9:06 pm » Post: #7 » Download Post
yes crank cases sealed properly with kawasaki three bond when I put new crank in
Sat Mar 04, 2006 9:14 pm » Post: #8 » Download Post
Check the TPS connector as this can make them hicup very badly at around these RPM's
Did it do it before you rebuilt the engine? Has it just started over night or slowly get worse over time?
nsr Moggy
Sat Mar 04, 2006 9:14 pm » Post: #9 » Download Post
also should have said that the bike pulls really well when you get past the flat spot
nsr Moggy
Sat Mar 04, 2006 9:20 pm » Post: #10 » Download Post
don't want to sound thick but whats the TPS connector. Also problem was not there when I first got the bike running as I had drilled out pilot jets but this made the bike not want to pull higher in the rev range (flooding) this is better now with new jets. Not sure what bike was like before rebuild as it was a non runner
Sat Mar 04, 2006 9:26 pm » Post: #11 » Download Post
The TPS is the Throttle Posistion Sensor, its mounted on the right hand side of the carbs and has a clear/white-ish 3 pin connector just under the frame brace infront of the carbs.
If the bike is running stock jetting with any kind of air box mods or exhaust then you need to have a play with the jetting as this can cause simular probs as to what you are having on WOT. Im guessing the bike pulls fine as long as youre not on WOT
nsr Moggy
Sat Mar 04, 2006 9:31 pm » Post: #12 » Download Post
bike is all completely standard apart from derestriction by the wiring splices orange and blue wire and GPS don't understand what you mean by WOT
Sat Mar 04, 2006 9:34 pm » Post: #13 » Download Post
Wide Open Throttle.
nsr Moggy
Mon Mar 06, 2006 8:52 am » Post: #14 » Download Post
thanks for help help with this put a set of 38 slow jets in that had been slightly drilled runs perfectly now so going to get some 40's and some 42's off apex. Only thing I can put this down to is non standard air filter got some foam from local bike shop and cut my own
Mon Mar 06, 2006 10:21 am » Post: #15 » Download Post
Another NSR back to it's best! Wink
