i need a new low beam bulb
and my instrument panel doenst light up fully
(at night i can barely see anything)
can anyone give me part numbers or bulbs / fuses that will work
Thanks!
Cant wait till its time to ride
the bike was alsmost sorted last year so if im lucky just a few more things and ill be ripping down the rd _________________ Koren
2 Strokes and I'm Off
The high & low beam is in one bulb. I wasn't able to find the 60/35w bulb at the local shops. I don't recall what watt bulb I ended up buying but I don't think a higher watt bulb would cause any problems as long as it's 12 volt.
My bike isn't back together so I'm not positive on the last statement. I will find out soon enough.
The lights on the instument panel are on the back side. Follow the wires to the rubber groments & you will find the lights behind there. Take them to an auto parts store & they should be able to help you. Here's a picture.
Yes, spring is here and it is brighter, wetter and cccold at the mo.
Hoping to get stuck in to the bikes soon - just needs to be a little warmer coz im a pussy and dont like cold fingers. _________________ These aren't the droids you're looking for.
