oil/water temp
fstnsr
oil/water temp
Mon Mar 20, 2006 6:16 am » Post: #1 » Download Post
is there any difference in measuring oil and water temp? surely they both will pretty much give u the engine temp which is what one wants.
94 mc28 SE
mick
Mon Mar 20, 2006 8:28 am » Post: #2 » Download Post
Oil temp wont tell you much as the gearbox is completely seperate.
fstnsr
Mon Mar 20, 2006 9:14 am » Post: #3 » Download Post
sorry my mistake it is actually on a klx super motard
94 mc28 SE
Barry_MC21
Mon Mar 20, 2006 9:44 am » Post: #4 » Download Post
If anything you want the oil temp as water will be upto normal operating temp long before the oil is. And its the oil thats the more important one. Wink
Something alot of people dont realise! Confused
Tue Mar 21, 2006 12:08 am » Post: #5 » Download Post
Depends. Water temp is more accurate since water reacts to temp changes much quicker. You're right in that the oil will take longer to reach 'normal', but it will also take longer to reflect and change up or down.
Oil is also designed to work effectively over a large range these days, so even though it's not fully warm, it's still protecting.
Oil is also not pumped round the head to cool it, whereas water is. The water should be hotter as that's what cools the combustion chamber.
Basically, water temp is the crucial one!
Colin NSR
Tue Mar 21, 2006 12:31 pm » Post: #6 » Download Post
Dave Ett wrote:Depends. Water temp is more accurate since water reacts to temp changes much quicker. You're right in that the oil will take longer to reach 'normal', but it will also take longer to reflect and change up or down.
Quick science lesson Shocked - Actually Dave it's the opposite - I think you'll find that Oil will warm up ("react to temp changes" as you say) much faster than water as the Specific Heat Capacity of Oil is about half that of liquid water ie. It takes twice as much energy (Joules) to heat water by the same amount as oil.
The water probably does heat up quicker in the case of a l/c 2-stroke though as it is being pumped around the heat source (cylinders) while the gearbox oil is warmed more slowly by conduction through the engine.
I think you're right re. water temp being more important though - this will tell you if the piston / cylinder area is warmed up sufficiently - afterall this is where the vast majority of 2 stroke failures occur.
Tue Mar 21, 2006 5:32 pm » Post: #7 » Download Post
Thanks Colin, memory chip reprogrammed! Wink
Colin NSR
Wed Mar 22, 2006 10:58 am » Post: #8 » Download Post
That's OK dave Very Happy
Sorry if the post was a bit nerdy. I'm a chemistry graduate thinking about going into teaching so couldn't resist.
Wed Mar 22, 2006 3:57 pm » Post: #9 » Download Post
I liked the post! Then again, as people often like to remind me, I'm a geek!* I do like to see the more technical discussions here on this Forum though.
*I imagine Fontyyy found it interesting too! Wink
Colin NSR
Wed Mar 22, 2006 4:06 pm » Post: #10 » Download Post
Thanks Andy, it's good to know all that time being educated wasn't wasted Very Happy .
Though I was for most of it...
Wed Mar 22, 2006 4:26 pm » Post: #11 » Download Post
You ruined that last post with the extra comment in parentheses! I'd have appreciated, "Though I was for most of it..." - much more subtle! Laughing
Colin NSR
Wed Mar 22, 2006 4:33 pm » Post: #12 » Download Post
There you go Andy...subtlety restored Very Happy .
What the hell is a parenthesesesesthingy - I'm a only a bit of a geek you know?
Shocked
ahug030
Thu Mar 23, 2006 10:43 am » Post: #13 » Download Post
Its more about dead-time really rather than heat transfer... hey all the engineering training in the world can't help me shoe-horn an '18 loom into a '16, but thats another thread Wink
'87 MC16
Thu Mar 23, 2006 5:55 pm » Post: #14 » Download Post
Best send it all to me then, and I'll use it instead of the PGM-III stuff I have for the MC16 project!! Very Happy
ahug030
Fri Mar 24, 2006 3:27 am » Post: #15 » Download Post
Andy, is it feasible to do this? I just bought a pgm-2 loom for a decent price and a set of '18 carbs. I checked it out last night, in some places the connectors are just different but wires (at least their colours) are the same, but in others the two looms don't seem to be analogous...
'87 MC16
