When fitting a rear cylinder head to the front cylinder on an MC21 which direction does the water pipe face? I`m using a standard radiator. _________________ `85 RG500
`90 MC21
`91 KTM 200 EGS now sold
`07 KTM 530 EXCR Supermoto
`04 TNT1130 (deisel yes but what fun!!)now with an 07 engine!!!!
Er, as long as you have the right hose for the conversion (tyga do one), it only goes one way. you CANT use the standard hose. Ive had mine done and i cant remeber if its down or to the right as you sit on the bike!
I`ve found a picture of Jamie Cresswell` on bikepics!
The outlet is mounted at the bottom.
Thanks _________________ `85 RG500
`90 MC21
yeah sorry forgot i had that pic up there!!! you should see the hose is difrent also!! And 1 last thing one of the studs is a bit short and may need replacing, I got mine from TYGA !!!
