Hi All
Will MC18 HRC air box fit (like HONDA RS250 has)on MC28 model? _________________ 1996 HONDA RS250
No. the frame rails are closer together on an 18. _________________ MC21SP Plaything
if the frame rails on the 18 are closer together then the Airbox must be narrower that a 28,if that's ture then a 18 airbox should fit a 28 which has wider frame,should'nt it?
Well you'd think so eh? But IIRC the HRC unit isn't a true airbox. It uses the frame rails as side portions to create a sort of sealed area, along with the underside of the tank.
Could be wrong as I've not spent much time looking at one, but that's what I deduced! _________________ MC21SP Plaything
