give me some me more detail of what you want and i will see what i can do for you, no promises
it should be a plate that connects to the frame, to the 2 points where the standard footrests connect. The rest of the plate should enable the std. footrests to be moved back and/or up within, lets say 2-3cm back and 3 cm up (or what people want) from standard position, which would give you 6-9 threaded holes.
It should be bent or machined so that the rests wouldn't be moved outwards but only back and up.
The plate should be stiff enough so the rests are stable.
I have seen some plates, some time back, but can't find them again.
they could be bent out of stainless, that would be easy/cheap maybe a little heavy, but they could be straightened easily after e crash or machined out of aluminium, but then would probably have to be replaced after a crash.
A longer gearchange arm should of course also be found/made. _________________ Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
The plates would also be of value to people who contemplate buying an expensive rearset, but don't know how long back and up they want.
they could buy some cheap plates to test the position and then find a suitable rearset. _________________ Poul
MC21SE, KISS box
Dave Ett is the man for cheap (nasty?) alternatives to rearsets, all you need is a bit of steel (preferably rusty) to move the bottom rear set hole back 3/4" or so and thus the peg up quite a bit, there's only point in doing one side as on the other side the pipe grounds out first. Dave will tell you which side, I believe the right hand side benefits from a slight lift.
TBF just buy some rearsets. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
scroll down to Lucas Fodhviler[url]http://www.sayjes.dk/servicep.html [/url] _________________ Poul
MC21SE, KISS box
