Well my mc21 is up and running ( After a year ). I did the rear head conversion while it was apart. I found out today that the front sparkplug wire is too short to reach the sparkplug from the stock mount. I was thinking of making a longer mount for the coil to mount on.
What other options do I have to fix this problem ? _________________
If you use th eshort plug and cap, the lead is just long enough!
When I first did mine, before using the HRC parts, I simply cable-tied (tie wrapped) the coil to the clutch cable. _________________ Andy.
