Need help with Jha pipes leaking
Vin
Wed May 10, 2006 2:58 am » Post: #1 » Download Post
I have a set of Jha pipes that leak from the part where the pipe connects to the flange. Does anyone else here have that problem and a solution?
Wed May 10, 2006 3:34 am » Post: #2 » Download Post
All Jha pipes do that Very Happy
Wed May 10, 2006 3:36 am » Post: #3 » Download Post
Seriously though, there's a crinkly seal in the Jha flange that gets crushed in no time and causes the leak. The best way to to use a good smear of Hi-temp RTV on the manifold before you put the pipe on, then give it half an hour or so to cure before starting.
Steve C
Wed May 10, 2006 3:37 am » Post: #4 » Download Post
Very high temp Red silicon will work for a while Shocked
rc46
Wed May 10, 2006 7:36 am » Post: #5 » Download Post
MMM, my TYGA's do that as well? Is it cause for concern? should i wip em off and use some of that RVT stuff? Confused I thought it was okay as its a spring that holds it on and its never gona be as good as a nut n bolt!
Wed May 10, 2006 7:48 am » Post: #6 » Download Post
The nuts only tighten the actual manifold down onto the gasket. That's the first part sealed just like the stock pipes. The sliding fit of the pipe onto the manifold also needs sealing, and this is where the sealer comes in. I use Permatex Hi-Temp. Comes in a red tube and smells pretty sharp. Make sure you degrease the manifolds and pipes before using the sealer or it won't seal properly.
rc46
Wed May 10, 2006 9:27 am » Post: #7 » Download Post
Cool, will do!! Is there a chance that damage could be done if not sealed properly? Ive already done a track day and it seemed to go fine, but i got another day comming up on the 24th, so need to know if its worth doing before hand, if there is no thret of damage ill wait as i gotta take it all off to fit the new suspension anyway, Cheers
maxim
Wed May 10, 2006 11:13 am » Post: #8 » Download Post
No it'll be fine RC. They all splurge out the burnt oil if not sealed but you wont affect the mixture or breathing from it doin it. It's just messy!
rc46
Wed May 10, 2006 12:55 pm » Post: #9 » Download Post
Cool, thanks for the reply max, I can do messy, but cant do broken just yet LOL Smile .. I had her stipped down the other day and cleaned it all off the fairing and chambers, so ill wait until after oulton and do it again but with a sealer and fit my new SP suspension at the same time!!! Very Happy
mick
Wed May 10, 2006 1:05 pm » Post: #10 » Download Post
My SP rear shock is going on before Oulton Laughing
ps. sorry cj555rally, Wink
rc46
Wed May 10, 2006 1:16 pm » Post: #11 » Download Post
bit of a thread hijack, I got mine from MAtt and PAul, awsome, new forks looks ace as dose the rear, but my r stuff works so if it aint broke dont fix it... especially with oulton comming up... Ill have time afterwards to fit and fiddle!!!
cj555rally
Thu May 11, 2006 7:21 pm » Post: #12 » Download Post
ps. sorry cj555rally, Wink[/quote]
Mick,no worries! Gonna let maxton do somethin with mine i think. Smile
Vin
Fri May 12, 2006 3:40 am » Post: #13 » Download Post
Ok, I think I will try to get some sealant and seal it. It sure is messy though
sparky
Mon May 15, 2006 2:23 am » Post: #14 » Download Post
do the Jha pipes use 2 orings in the flange?
the ones I have have 2 groves which look like they are for a pair of orings on the flange. the pipes then slide over them.
Mon May 15, 2006 12:10 pm » Post: #15 » Download Post
rc46 wrote:its never gona be as good as a nut n bolt!
Remember that a two stroke engine vibrates a lot, and if the exhausts were solid mounted, they'd need to be very strong to withstand the vibration, hence the reason the lightweight pipes are best fastened on with springs.
