Hi all, what does it take to get ZXR400 forks on my mc28? Other than getting the ZXR triples pressed on to the NSR stem. What brakes/axle/wheel?
just seeing what my options are.
thanks _________________ MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
I did the conversion on a buget. was not the best but it worked.
First had the NSR bearing cones machined to fit the ZXR stem securely. then that all bolted up nicely.
Ran the NSR calipers straight on the ZXR fork with the NSR discs and wheel. The brakes were biting the disc but not the whole pad was in contact. VFR discs would have been great.
Used some washers to space the wheel as the axle was the same size. _________________ 94 mc28 SE
