mc16 fork oil levels?
mike
Guest
Mon Oct 04, 2004 9:41 am » Post: #1 » Download Post
Hi,
just finished putting new fork seals in my mc16 nsr, unsure of how many mls fork oil to put in each leg? just read another post which said for the mc18 its 410cc per side. is this the same for the mc16?
Thanks
Tue Oct 05, 2004 2:35 pm » Post: #2 » Download Post
The MC16 requires 383cc of ATF in each leg, to a level of 108mm from the top of the leg.
The front fork air pressure should be set to 0-0.4kg cm2, and the spring free length should be no less than 285.7mm.
Fork top bolt torque: 1.5-3.0kg-m.
