Ok i was reading an earlyer thread about restrictive spannies and it was mentioned that the mc18s were double skinned? would i be correct in assuming that the mc16 pipes are too? anyways im gonna have a play with spannies does anyone know the correct cone/ spannie dimensions for the standard inner part?
cheers
Mike
ahhh im getting dragged further into this nsr thing
M, I will have some pipe specs from you c/o the fabled MA. Just what you need - you can then get Nigel Kimbers to do his thing and make you some quality pipes.
I phoned you tonight but no answer, your carbs are boxed up - just need the address.
BTW - what type of mount does Nige use on those cans you have ?
